Tout ce qui a été posté par heurb le gros
traduction de thermes techniques
heurb le gros a répondu au sujet de heurb le gros dans Mécanique Générale
le but de ce topic est de permettre a quiconque d'avoir rapidement la traduction d'un therme technique lorsqu'il consulte ce site...toutes les infos sont bonnes a prendre...merci pour l'aide... tournee de mousse pour tout le monde!!!! -
E: Exhaust: Catalytic Converter: Clamp: Exhaust Header: Exhaust Manifold: Exhaust Manifold Gasket: Exhaust System Hanger: Muffler: Pipe: Fuel/Air: Air Cleaner Mounting Gasket: Air Filter: Carburetor: Carburetor Choke Pull Off: Carburetor Choke Thermostat: Carburetor Dash Pot: Carburetor Mounting Gasket: Fuel Cap Tester Adapter: Fuel Filter: Fuel Pre-Heater Hose: Fuel Pump: Fuel Pump Gasket: Fuel Tank: Fuel Tank Cap: Fuel Tank Selector Valve: Fuel Tank Sending Unit: Fuel Tank Strap: Hardware: Machine Screw: Heat & Air Conditioning: A/C Accumulator: A/C Compressor: A/C Compressor Clutch: A/C Compressor Clutch Bearing: A/C Condenser: A/C Evaporator Core: A/C Expansion Valve: A/C Receiver Drier: A/C System Valve Core and Cap Kit: Blower Motor: Blower Motor Wheel: Heater & AC Controls: Heater Case Drain Hose: Heater Control Valve: Heater Core: Heater Hose: Valve: Ignition: Coil Resistor: Control Module: Distributor: Distributor Cap: Distributor Cap and Rotor Kit: Distributor Ignition Pickup: Distributor Pole Piece Assembly: Distributor Rotor: Distributor Vacuum Advance: Ignition Coil: Ignition Coil Housing: Ignition Reluctor: Ignitor: Spark Plug: Spark Plug Non-Fouler: Spark Plug Wire Set: Tune-Up Kit: Literature: Repair Manual: Steering: Drag Link: Gear Box: Idler Arm: Power Steering Control Valve Seal Kit: Power Steering Filter: Power Steering Pressure Hose: Power Steering Pump: Power Steering Pump Drive Shaft Seal Kit: Power Steering Pump Rebuild Kit: Power Steering Pump Seal Kit: Power Steering Pump Shaft Seal: Power Steering Reservoir Line Hose: Power Steering Return Hose: Rack and Pinion Seal Kit: Steering Damper: Steering Damper Bellows: Steering Gear: Steering Gear Input Shaft Seal: Steering Gear Pitman Shaft Seal: Steering Gear Rebuild Kit: Steering Gear Seal Kit: Steering Gear Worm Shaft Bearing: Steering Gear Worm Shaft Seal: Tie Rod End: Tie Rod End Adjusting Sleeve: Suspension: Alignement Kit Alignment Thrust Plate: Ball Joint: Coil Spring: Control Arm: Control Arm Bumper: Control Arm Bushing: Leaf Spring: Leaf Spring Bushing: Leaf Spring Helper: Shock Absorber: Stabilizer Bar Bushing: Stabilizer Bar Link: Strut Rod Bushing: Strut Rod Lock Nut: Transfer Case: Idler Shaft Bearing: Input Shaft Bearing: Input Shaft Seal: Oil Pump Housing Seal: Output Shaft Bearing: Output Shaft Seal: Shift Shaft Seal: Transmission-Automatic: Auto Trans Oil Cooler: Bands: Bushings: Clutch Cam Bearing: Clutch Plates: Extension Housing Bearing: Extension Housing Seal: Filter Kit: Flexplate: Front Pump Oil Seal: Gaskets: Master Repair Kit: O-Rings & Seals: Oil Pan: Oil Pan Gasket: Overhaul Package: Ring Gear: Sealing Rings: Selector Shaft Seal: Shift Kit: Shift Shaft Oil Seal: Sprag Assembly: Torque Converter Oil Seal: Transmission Mount: Washers: Transmission-Manual: Countershaft Bearing: Drive Shaft Bearing: Drive Shaft Seal: Flywheel: Flywheel Bolt: Flywheel Ring Gear: Input Shaft Bearing: Input Shaft Seal: Main Shaft Bearing: Main Shaft Pilot Bearing: Main Shaft Seal: Output Shaft Bearing: Output Shaft Seal: Reverse Idler Bearing: Shift Shaft Seal: Top Gasket: Transmission Mount Wheel/Tire: Wheel: Wheel Lug Nut: Wheel Lug Nut Lock: Wheel Lug Stud: Wiper & Washer: Washer Pump: Wiper Arm: Wiper Blade: Wiper Blade Refill: Wiper Linkage Bushing: Wiper Motor: -
ben voila,moi et le language technique,on est pas pote...c'est galere quand on a un niveau linguistique digne du niveau de la mer... c'est pourquoi,je m'en remet a vos competences...quelqu'un pourrait t'il traduire ces thermes...merci.... B: Belt Drive: Accessory Drive Belt: Idler Pulley: Body-Exterior: Bumper Face Bar: Bumper Filler: Door Hinge: Door Hinge Pin & Bushing Kit: Door Lock Kit: Door Seal / Weatherstrip: Fender: Front End Cover: Grille: Headlamp Assembly: Headlight Adjusting Screw: Hood: Hood Protector: Outside Mirror: Outside Mirror Glass: Park Lamp Assembly: Tail Lamp Lens: Window channel: Body-Interior: Carpet: Dash Board Cover: Floor Mat: Inside Rear View Mirror: Power Window Motor: Power Window Motor Gear: Turn Signal Cam Repair Kit: Window Crank Handle: Brake/Wheel Hub: Belt Drive: Body-Exterior: Body-Interior: Brake/Wheel Hub: Clutch: Cooling System: Drivetrain: Electrical: Electrical-Connector: Electrical-Lamp & Socket: Electrical-Switch & Relay: Emission: Engine: Exhaust: Fuel/Air: Hardware: Heat & Air Conditioning: Ignition: Literature: Steering: Suspension: Transfer Case: Transmission-Automatic: Transmission-Manual: Wheel/Tire: Wiper & Washer: C: Clutch: Clutch Alignment Tool: Clutch Fork: Clutch Kit: Clutch Pilot Bearing: Clutch Pilot Bushing: Clutch Pressure Plate: Clutch Pressure Plate and Disc Set: Clutch Release Bearing: Cooling System: By Pass Hose: Coolant Hose Coolant Temperature Sender: Coolant Temperature Sensor: Engine Cooling Fan Blade: Engine Cooling Fan Clutch: Engine Cooling Fan Spacer Kit: Radiator: Radiator Cap: Radiator Cap Adapter: Radiator Drain Petcock: Radiator Lower Hose: Radiator Upper Hose: Thermostat: Thermostat Housing Gasket: Thermostat Housing/Water Outlet: Water Outlet Gasket: Water Pump: Water Pump Gasket: D: Drivetrain: Axle Differential Bearing: Axle Differential Bearing and Seal Kit: Differential Cover Rear Gasket: Differential Gear Case: Differential Pinion Bearing: Differential Pinion Seal: Drive Shaft Center Support Bearing: Front Drive Shaft Bushing: Universal Joint: Universal Joint C-clip: Universal Joint Strap Kit: E: Electrical: Alternator: Alternator Brush Set: Alternator Capacitor: Alternator Commutator End Bearing: Alternator Diode: Alternator Drive End Bearing: Battery Cable: Engine Control Module (Computer): Flasher: Generator Brush: Horn: Instrument Cluster Voltage Regulator: Starter Bearing: Starter Brush: Starter Bushing: Starter Drive: Starter Motor: Starter Solenoid: Starter Solenoid Repair Kit: Turn Signal Flasher: Voltage Regulator: Electrical-Connector: A/C Clutch Coil Connector: A/C Relay Connector: Headlight Dimmer Connector: Heater & A/C Switch Connector: Ignition Control Module Connector: Pigtail: Trailer Connector: Voltage Regulator Connector: Electrical-Lamp & Socket: Back Up Lamp Socket: Back Up Light: Brake Lamp Socket: Brake Light: Courtesy Light: Dome Light: Headlamp Socket: Headlight: High Beam Indicator Light: Instrument Cluster Lamp Socket: Instrument Panel Light: License Light: Marker Lamp Socket: Parking Lamp Socket: Parking Light: Side Marker Lamp Socket: Side Marker Light: Step Light: Tail Lamp Socket: Tail Light: Turn Signal Lamp Socket: Turn Signal Light: Electrical-Switch & Relay: A/C Clutch Switch: A/C System Switch: A/C and Heater Control Switch: Back Up Lamp Switch: Brake Light Switch: Dimmer Switch: Distributor Thermal Vacuum Switch: Door Jamb Switch: Door Lock Cylinder Switch: Door Lock Relay: EGR Time Delay Switch: Electric Fuel Pump Inertia Switch: Fuel Injection Pump Switch: HVAC Blower Control Switch: Headlight Switch: Horn Relay: Ignition Starter Switch: Neutral Safety Switch: Oil Pressure Switch: Ported Vacuum Switch: Starter Relay: Starter Solenoid Switch: Starter Switch: Turn Signal Switch: Emission: Air Charge Temperature Sensor: Air Check Valve: Air Pump: Air Pump Check Valve: Air Temperature Sensor: Crankcase Breather Element: EGR Valve: EGR Valve Gasket: Emission Vacuum Valve: HVAC Control Duct Hose: Oxygen Sensor: PCV Valve: PCV Valve Grommet: Vapor Canister Filter:
je monte ca cet aprem...au pire,si je remonte tout a l'envers,je viendrais en frranche comte en marche arriere...c'est ca???
tu sais bouteille,elle est pas encore grabataire notre cannelle...he puis,il est doux comme un agneau notre dan...sauf avec les bouteilles de san pelegrino...
rigole,mais ca a une gueule terrible... au fait,ca va etre le meme moteur que l'autre?
tu m'allonge un peu la fourche,tu me colles un autocollant hd a la place du honda et ca fait presque un chop' harley...
c'est trop beau pour toi...je t'achete le tout pour 500 euros...c'est bien parce que c'est toi... B)
c'est pas un v8 mais c'est cool a voir quand meme... http://www.dailymotion.com/playlist/x6vgy_...age-moteur_auto
petite animation... http://www.dailymotion.com/relevance/searc...rald-900ss_auto
j'ai regarde par curiosite sur summit,y'a plusieures ref...j'en perd mon chinois!!! B)
comment puis je connaitre la duration de mon arbre a came d'origine,c'est a dire d'un 360 ci?
ben,s'ils sont aussi doues que ceux de chez nous...c'est que ca vit pas longtemps une subaru sur autoroute... j'imagine meme pas avec une stang....
le delire...un bus!!!
on les reconnait facilement les harleyboys...ils ont le mollet droit plus muscle que le gauche...
la guns...one more reason...en qualite pas terrible...
un grand merci!!!! http://www.dreams-cars.org/forum/public/style_emoticons/default/ivrogne.gif
limp bizkit...rollin' http://fr.youtube.com/watch?v=Mz2jVe3AGaY
bon,tout est demonte...quelqu'un aurait t'il le couple de serrage pour les culasses svp???
oh,je sais pas si on est meilleur a besancon... pour ton info,j'ai toute ma famille qui habite dans les vosges, a cote de mirecourt...j'y aie vecu...mais la vie fait qu'on voyage...et les voyages forment la jeunesse,non? http://www.dreams-cars.org/forum/public/style_emoticons/default/biggrin.png
alors la plouc,tu me decois...toi qui d'habitude nous pond la replique du tonnerre,la tu cales...
carte grise avec mention chassis modifie??
