couguy
Membres Inactifs
Tout ce qui a été posté par couguy
  1. There is a trend in the works that takes a modern Corvette chassis, jettisons the stock fiberglass bodywork and adds a new shell that mimics the look of an older, classic 'Vette. We have seen Classic Reflection Coachworks' take on the '62 'vert with C5 underpinnings, and now a company by the name of Blue Fusion has tackled the iconic split window. One problem: their press release continually refers to the 1966 split window, which doesn't exist as the only year the two-piece rear glass was produced was '63. But, let's not let silly little things like facts get in the way. The resultant Rossi 66 cribs the workings of a modern C6 Corvette and adds a unique Sting Ray look. Blue Fusion plans to debut its Rossi 66 at the upcoming SEMA event in November, assuming that the company is able to find the funding it needs to actually produce its first car. So far, all we have to look at are the renderings below, though we can clearly see that the '66 '63 body looks much better grafted onto a modern platform than the '62 does. We'll see if it makes an appearance in Sin City later this year.
  2. issue d'une presentation à Monterey !
  3. 1954 Firebird XP-21 1938 Buick Y-Job 1956 Buick Centurion XP-301 1953 Buick Wildcat 1 1954 Buick Wildcat II 1954 Oldsmobile F-88 Roadster 1959 Chevrolet Corvette Stingray 1959 Cadillac Cyclone XP-74 1958 Firebird III 1951 LeSabre Firebird II 1953 Cadillac Le Mans 1959 Stingray 1951 Buick XP300 1953 Pontiac Parisienne The first Corvette from 1953 1955 Chevrolet Biscayne XP-37 1955 La Salle II Roadster
  4. couguy
    1954 Cramer Comet
    There are hot rods, there are hot rods, and then there's "Um... what is that?" Tom Cramer, an ex-GI and mechanic in Omaha says, "I wanted to see what would happen if you put a really high powered engine in a chassis." Sound familiar? That was in 1953. So he found a fresh 12-cylinder 1,710-cubic-inch Allison airplane engine that produces 1,350-hp/1,500 ft-lb and got to work. The body of the Cramer Comet was Frankensteined from De Sotos, Dodges, Oldsmobiles, Buicks, Studebakers, Cadillacs, Lincolns, and Fords. Part of the tubular chassis is made up of four-inch refrigerator tubing filled with coolant that runs to a rear-mounted radiator. The engine is mounted in reverse and is heavily insulated -- it gets hot in there. Power is sent through a drive shaft mounted between two truck universals and on to a four-speed transmission. The top speed is said to be 160 MPH, which is low for so much power, but probably sensible considering it's hand built. Check out that center console. To start the car, the driver (pilot?) sets the throttle quadrant to ten-percent, cranks the fuel mixture to full rich, turns the spark lever to retard, flips the master switch, turns the magnetos on, turns the fuel boost and primer switches on, flips the starter control first to energize and then to on. And then it's time to fly, hopefully not in the literal sense. Tom didn't get rid of the car until 1991 and it's now up for auction for the first time at this year's Sport & Classics of Monterey held by RM Auctions August 15 and 16. It's expected to fetch up to $300,000. Even if you don't plan to buy, you should check out the gallery of high-res photos below for evidence of how powerful elbow grease is.
  5. fascinante trooper ton histoire dont tu m'avais déjà un peu parlé au séquoia et bravo pour ton soucis des détails à atteindre !
  6. couguy
    Dodge Coronet 1958
    de toute beauté cette voiture, et en effet on comprend aisemment que tu dois savourer chaques instants à rouler avec !!
  7. couguy
    Buick Regal 1976
    superbe ta buick, félicitation !!
  8. couguy
    Nouveau james Bond
    pour rester dans le sujet James, une belle idée de cadeau pour "presque rien", £750 B)
  9. couguy
    petite limousine
    mon véhicule de rêve, classe, discret, pratique, maniable, mais en plus grand !!! B)
  10. D'autres :
  11. couguy
    Dodge Coronet 1958
    c'est vrai qu'on a un peu tendance à ce mefier des professionnels de l'automobile avec toutes les annecdotes relatées par ci par là (prix exorbitants, qualité du travail, pièces réellement à changer..)! t'as beaucoup de talents jérémie et la respect d'autrui, et ça re donne envie de confier son véhicule en toute quietude, bravo !
  12. couguy
    Dodge Coronet 1958
    magnifique ta restoration, bravo !!
  13. couguy
    Nettoyage Moteur...
    pour info willscad , je n'ai pas recherché ce site, je le connais déjà car une des personnes du site en question que je connais sur DEC est enfin dispo, et va traiter l'ensemble de la carrosserie de ma vette la semaine prochaine. dans le cas présent du moteur, on peut trouver ça comme post en fouillant quelques secondes : http://www.esthauto.com/viewtopic.php?t=4411
  14. couguy
    Nettoyage Moteur...
    quoi qu'il en soit bouteille, les produits Meguiars ne sont pas réputés pour être de la mauvaise qualité et il n'utilise que des produits de haute qualité . je vous glisse le lien d'un site où est extrait mon post ci dessus. vous trouverez toutes les astuces et produits adéquats pour chaques éléments à traiter ! http://www.esthauto.com/index.php?sid=9e98...4a484b1a396c326
  15. couguy
    Nettoyage Moteur...
    pour ceux qui cherchent un résultat assez "pointu", voici ce qu' utilise un pro du nettoyage, dans le cas précis d'un moteur visiblement pas souillé, mais peut être tout aussi efficace pour un qui l'est ! extrait : J'ai donc pris la brosse Autoglym, que j'imbibais de Meguiars Super Degreaser. D'abord diluer en 8:1, je suis repassé sur du 4:1 On peut voir la différence, gauche fait, droite non. Les plastiques qui entourent le moteur subissant de fortes chaleurs ont été traités avec un nouveau gallon de chez Megs que je voulais tester : all season dressing Produit plutot concentré et bien gras, qui je pense doit avoir un grand intéret sur les plastiques de passages de roues.
  16. la voici ainsi que l'interview du réalisateur dans le lien ! http://shadowyflight.com/news/2008/04/excl...mpson-part1.php
  17. couguy
    Photos d'époque
    c'est le matin que j'ai toujours plus la patate !!!
  18. couguy
    Photos d'époque
  19. couguy
    Ford Mustang 1968
    je viens de parcourir toutes les pages, ENORME TA RESTO ET PREPA !!! bravo, le soucis de la perfection, j'adore ça !
  20. superbe post que je découvre là !!
  21. beau boulot, bravo !
  22. couguy
    Photos d'époque
    http://www.autoblog.com/photos/1954-mercur...concept/737393/
  23. sympa ces vidéos promotionnelles !
