ben voila,moi et le language technique,on est pas pote...c'est galere quand on a un niveau linguistique digne du niveau de la mer... :)
c'est pourquoi,je m'en remet a vos competences...quelqu'un pourrait t'il traduire ces thermes...merci.... :)
B:
Belt Drive:
Accessory Drive Belt:
Idler Pulley:
Body-Exterior:
Bumper Face Bar:
Bumper Filler:
Door Hinge:
Door Hinge Pin & Bushing Kit:
Door Lock Kit:
Door Seal / Weatherstrip:
Fender:
Front End Cover:
Grille:
Headlamp Assembly:
Headlight Adjusting Screw:
Hood:
Hood Protector:
Outside Mirror:
Outside Mirror Glass:
Park Lamp Assembly:
Tail Lamp Lens:
Window channel:
Body-Interior:
Carpet:
Dash Board Cover:
Floor Mat:
Inside Rear View Mirror:
Power Window Motor:
Power Window Motor Gear:
Turn Signal Cam Repair Kit:
Window Crank Handle:
Brake/Wheel Hub:
Belt Drive:
Body-Exterior:
Body-Interior:
Brake/Wheel Hub:
Clutch:
Cooling System:
Drivetrain:
Electrical:
Electrical-Connector:
Electrical-Lamp & Socket:
Electrical-Switch & Relay:
Emission:
Engine:
Exhaust:
Fuel/Air:
Hardware:
Heat & Air Conditioning:
Ignition:
Literature:
Steering:
Suspension:
Transfer Case:
Transmission-Automatic:
Transmission-Manual:
Wheel/Tire:
Wiper & Washer:
C:
Clutch:
Clutch Alignment Tool:
Clutch Fork:
Clutch Kit:
Clutch Pilot Bearing:
Clutch Pilot Bushing:
Clutch Pressure Plate:
Clutch Pressure Plate and Disc Set:
Clutch Release Bearing:
Cooling System:
By Pass Hose:
Coolant Hose
Coolant Temperature Sender:
Coolant Temperature Sensor:
Engine Cooling Fan Blade:
Engine Cooling Fan Clutch:
Engine Cooling Fan Spacer Kit:
Radiator:
Radiator Cap:
Radiator Cap Adapter:
Radiator Drain Petcock:
Radiator Lower Hose:
Radiator Upper Hose:
Thermostat:
Thermostat Housing Gasket:
Thermostat Housing/Water Outlet:
Water Outlet Gasket:
Water Pump:
Water Pump Gasket:
D:
Drivetrain:
Axle Differential Bearing:
Axle Differential Bearing and Seal Kit:
Differential Cover Rear Gasket:
Differential Gear Case:
Differential Pinion Bearing:
Differential Pinion Seal:
Drive Shaft Center Support Bearing:
Front Drive Shaft Bushing:
Universal Joint:
Universal Joint C-clip:
Universal Joint Strap Kit:
E:
Electrical:
Alternator:
Alternator Brush Set:
Alternator Capacitor:
Alternator Commutator End Bearing:
Alternator Diode:
Alternator Drive End Bearing:
Battery Cable:
Engine Control Module (Computer):
Flasher:
Generator Brush:
Horn:
Instrument Cluster Voltage Regulator:
Starter Bearing:
Starter Brush:
Starter Bushing:
Starter Drive:
Starter Motor:
Starter Solenoid:
Starter Solenoid Repair Kit:
Turn Signal Flasher:
Voltage Regulator:
A/C Clutch Coil Connector:
A/C Relay Connector:
Headlight Dimmer Connector:
Heater & A/C Switch Connector:
Ignition Control Module Connector:
Pigtail:
Trailer Connector:
Voltage Regulator Connector:
Back Up Lamp Socket:
Back Up Light:
Brake Lamp Socket:
Brake Light:
Courtesy Light:
Dome Light:
Headlamp Socket:
Headlight:
High Beam Indicator Light:
Instrument Cluster Lamp Socket:
Instrument Panel Light:
License Light:
Marker Lamp Socket:
Parking Lamp Socket:
Parking Light:
Side Marker Lamp Socket:
Side Marker Light:
Step Light:
Tail Lamp Socket:
Tail Light:
Turn Signal Lamp Socket:
Turn Signal Light:
A/C Clutch Switch:
A/C System Switch:
A/C and Heater Control Switch:
Back Up Lamp Switch:
Brake Light Switch:
Dimmer Switch:
Distributor Thermal Vacuum Switch:
Door Jamb Switch:
Door Lock Cylinder Switch:
Door Lock Relay:
EGR Time Delay Switch:
Electric Fuel Pump Inertia Switch:
Fuel Injection Pump Switch:
HVAC Blower Control Switch:
Headlight Switch:
Horn Relay:
Ignition Starter Switch:
Neutral Safety Switch:
Oil Pressure Switch:
Ported Vacuum Switch:
Starter Relay:
Starter Solenoid Switch:
Starter Switch:
Turn Signal Switch:
Emission:
Air Charge Temperature Sensor:
Air Check Valve:
Air Pump:
Air Pump Check Valve:
Air Temperature Sensor:
Crankcase Breather Element:
EGR Valve:
EGR Valve Gasket:
Emission Vacuum Valve:
HVAC Control Duct Hose:
Oxygen Sensor:
PCV Valve:
PCV Valve Grommet:
Vapor Canister Filter:
Et voila ! <_<
Grille: GRILLE
Headlight Adjusting Screw: VIS D'ASSEMBLAGE DES FEUX
Hood: CAPOT
Outside Mirror: MIRROIR EXTERIEUR
Outside Mirror Glass: GLACE DU MIRROIR EXTERIEUR
Inside Rear View Mirror: MIRROIR INTERIEUR
Power Window Motor: MOTEUR DE VITRE ELECTRIQUE
Body-Exterior: CARROSSERIE EXTERIEUR
Body-Interior: CARROSSERIE INTERIEUR Gné :)
Clutch: EMBRAYAGE doute
Cooling System: SYSTEME DE REFROIDISSEMENT
Drivetrain: TRAIN ROULANT doute
Engine: MOTEUR
Exhaust: ECHAPPEMENT
Heat & Air Conditioning: CHAUFFAGE ET CLIM'
Ignition: ALLUMAGE
Steering: DIRECTION
Suspension: SUSPENSION
Transmission-Automatic: FAUT PAS SE FOUTRE DE LA GUEULE DU MONDE NON PLUS !!! :)
Transmission-Manual: IDEM
Wheel/Tire: ROUE/PNEU
Wiper & Washer: ESSUIE GLACE
Engine Cooling Fan Blade: LAME D'HELICE DU SYSTEME DE REFROIDISSEMENT DU MOTEUR
Radiator: RADIATEUR
Water Pump: POMPE A EAU
Water Pump Gasket: JOINT DE POMPE A EAU
Electrical: MEME CHOSE
Alternator: MEME CHOSE
Modifié par Ilan
E:
Exhaust:
Catalytic Converter:
Clamp:
Exhaust Header:
Exhaust Manifold:
Exhaust Manifold Gasket:
Exhaust System Hanger:
Muffler:
Pipe:
Fuel/Air:
Air Cleaner Mounting Gasket:
Air Filter:
Carburetor:
Carburetor Choke Pull Off:
Carburetor Choke Thermostat:
Carburetor Dash Pot:
Carburetor Mounting Gasket:
Fuel Cap Tester Adapter:
Fuel Filter:
Fuel Pre-Heater Hose:
Fuel Pump:
Fuel Pump Gasket:
Fuel Tank:
Fuel Tank Cap:
Fuel Tank Selector Valve:
Fuel Tank Sending Unit:
Fuel Tank Strap:
Hardware:
Machine Screw:
A/C Accumulator:
A/C Compressor:
A/C Compressor Clutch:
A/C Compressor Clutch Bearing:
A/C Condenser:
A/C Evaporator Core:
A/C Expansion Valve:
A/C Receiver Drier:
A/C System Valve Core and Cap Kit:
Blower Motor:
Blower Motor Wheel:
Heater & AC Controls:
Heater Case Drain Hose:
Heater Control Valve:
Heater Core:
Heater Hose:
Valve:
Ignition:
Coil Resistor:
Control Module:
Distributor:
Distributor Cap:
Distributor Cap and Rotor Kit:
Distributor Ignition Pickup:
Distributor Pole Piece Assembly:
Distributor Rotor:
Distributor Vacuum Advance:
Ignition Coil:
Ignition Coil Housing:
Ignition Reluctor:
Ignitor:
Spark Plug:
Spark Plug Non-Fouler:
Spark Plug Wire Set:
Tune-Up Kit:
Literature:
Repair Manual:
Steering:
Drag Link:
Gear Box:
Idler Arm:
Power Steering Control Valve Seal Kit:
Power Steering Filter:
Power Steering Pressure Hose:
Power Steering Pump:
Power Steering Pump Drive Shaft Seal Kit:
Power Steering Pump Rebuild Kit:
Power Steering Pump Seal Kit:
Power Steering Pump Shaft Seal:
Power Steering Reservoir Line Hose:
Power Steering Return Hose:
Rack and Pinion Seal Kit:
Steering Damper:
Steering Damper Bellows:
Steering Gear:
Steering Gear Input Shaft Seal:
Steering Gear Pitman Shaft Seal:
Steering Gear Rebuild Kit:
Steering Gear Seal Kit:
Steering Gear Worm Shaft Bearing:
Steering Gear Worm Shaft Seal:
Tie Rod End:
Tie Rod End Adjusting Sleeve:
Suspension:
Alignement Kit
Alignment Thrust Plate:
Ball Joint:
Coil Spring:
Control Arm:
Control Arm Bumper:
Control Arm Bushing:
Leaf Spring:
Leaf Spring Bushing:
Leaf Spring Helper:
Shock Absorber:
Stabilizer Bar Bushing:
Stabilizer Bar Link:
Strut Rod Bushing:
Strut Rod Lock Nut:
Transfer Case:
Idler Shaft Bearing:
Input Shaft Bearing:
Input Shaft Seal:
Oil Pump Housing Seal:
Output Shaft Bearing:
Output Shaft Seal:
Shift Shaft Seal:
Auto Trans Oil Cooler:
Bands:
Bushings:
Clutch Cam Bearing:
Clutch Plates:
Extension Housing Bearing:
Extension Housing Seal:
Filter Kit:
Flexplate:
Front Pump Oil Seal:
Gaskets:
Master Repair Kit:
O-Rings & Seals:
Oil Pan:
Oil Pan Gasket:
Overhaul Package:
Ring Gear:
Sealing Rings:
Selector Shaft Seal:
Shift Kit:
Shift Shaft Oil Seal:
Sprag Assembly:
Torque Converter Oil Seal:
Transmission Mount:
Washers:
Countershaft Bearing:
Drive Shaft Bearing:
Drive Shaft Seal:
Flywheel:
Flywheel Bolt:
Flywheel Ring Gear:
Input Shaft Seal:
Main Shaft Bearing:
Main Shaft Pilot Bearing:
Main Shaft Seal:
Output Shaft Seal:
Reverse Idler Bearing:
Shift Shaft Seal:
Top Gasket:
Transmission Mount
Wheel/Tire:
Wheel:
Wheel Lug Nut:
Wheel Lug Nut Lock:
Wheel Lug Stud:
Wiper & Washer:
Washer Pump:
Wiper Arm:
Wiper Blade:
Wiper Blade Refill:
Wiper Linkage Bushing:
Wiper Motor:
Grille: (GRILLE) CALANDRE
Headlight Adjusting Screw: VIS (D'ASSEMBLAGE) DE REGLAGE DES FEUX
Hood: CAPOT
Outside Mirror: (MIROIR) RETROVISEUR EXTERIEUR
Outside Mirror Glass: (GLACE DU MIROIR) MIROIR DU RETROVISEUR EXTERIEUR
Inside Rear View Mirror: (MIROIR) RETROVISEUR INTERIEUR
Body-Interior: CARROSSERIE INTERIEUR Gné plancher, planche de bord, compartiment moteur, intérieurs de portières...
Clutch: EMBRAYAGE (doute) aucun doute
Drivetrain: TRAIN ROULANT (doute) boîte / arbre / pont
Engine: MOTEUR
Ignition: ALLUMAGE
Steering: DIRECTION
Wiper & Washer: ESSUIE GLACE & LAVE-GLACE
Engine Cooling Fan Blade: (LAME D'HELICE DU SYSTEME DE REFROIDISSEMENT DU MOTEUR) PALE DE VENTILATEUR
Radiator: RADIATEUR
Bon, je ne sais pas pour Ilan, moi j'ai soif, ça sera une bière...
Deux chef ! :wub:
P.S. Au Québec, on dit miroir, alors j'm'integre moi ! :hauhau::wub:
Modifié par Ilan
Ilan > grille c'est calandre
Phil me l'a deja corriger, on va pas tout faire en double, hein les jeunes ? :hauhau::wub:
... OKay ... disons que ce sera mon cadeau de Noël :hauhau:
le but de ce topic est de permettre a quiconque d'avoir rapidement la traduction d'un therme technique lorsqu'il consulte ce site...toutes les infos sont bonnes a prendre...merci pour l'aide...
tournee de mousse pour tout le monde!!!! :hauhau:
Bon je m'y colle dans l'ordre de ta demande
Belt Drive: courroie
Accessory Drive Belt: courroie d'accessoire
Idler Pulley: galet de direction
Body-Exterior: carrosserie extérieure
Bumper Face Bar: pare choc
Bumper Filler: joint de pare choc
Door Hinge: charnière de porte
Door Hinge Pin & Bushing Kit: goupille de charnière + kit de rondelles
Door Lock Kit: kit verrou de porte
Door Seal / Weatherstrip: joint de porte / lèche vitre
Fender: aile
Front End Cover:
Grille: calandre
Headlamp Assembly: porte lampe
Headlight Adjusting Screw: vis de réglage des phares
Hood: capot moteur
Hood Protector: protection capot moteur
Outside Mirror: rétroviseur extérieur
Outside Mirror Glass: vitre de rétro extérieur
Park Lamp Assembly: témoint de frein de stationnement
Tail Lamp Lens: cabochons de feux de position
Window channel: guide vitre
Body-Interior: intérieur (habitacle+sellerie)
Carpet: tapis (moquettes)
Dash Board Cover: dessus du tableau de bord
Floor Mat: tapis de sol
Inside Rear View Mirror: rétroviseur intérieur
Power Window Motor: moteur de lève vitre
Power Window Motor Gear: engrenage de moteur de lève vitre
Turn Signal Cam Repair Kit: kit de réparation pour câme d'indicateur de direction
Window Crank Handle: manivelle de lève vitre
Brake/Wheel Hub: moyeu de frein / moyeu de roue
Clutch: embrayage
Cooling System: système de refroisissement
Drivetrain: groupe motopulseur (moteur+boite+pont)
Electrical: electicité
Electrical-Connector: connecteur électrique
Electrical-Lamp & Socket: ampoule et douille
Electrical-Switch & Relay: contacteur électrique et relais
Emission: idem
Engine: moteur
Exhaust: echappement
Fuel/Air: essence / air
Hardware: quincaillerie
Heat & Air Conditioning: chauffage et air conditionné
Ignition: contact
Literature: documentation
Steering: direction
Suspension: idem
Transfer Case: boite de transfert (4x4)
Transmission-Automatic: idem
Transmission-Manual: idem
Wheel/Tire: roue / pneu
Wiper & Washer: essuie glace et lave glace
C:
Clutch: embrayage
Clutch Alignment Tool: outil de centrage pour embrayage
Clutch Fork: fourchette d'embrayage
Clutch Kit: kit d'embrayage
Clutch Pilot Bearing: roulement d'embrayage
Clutch Pilot Bushing: bague de roulement d'embrayage
Clutch Pressure Plate: plateau de pression
Clutch Pressure Plate and Disc Set: plateau de pression et jeu de disques
Clutch Release Bearing: butée d'embrayage
Cooling System: système de refroidissement
By Pass Hose: durite de dérivation
Coolant Hose durite de refroidissement
Coolant Temperature Sender: sonde de température (pour mano)
Coolant Temperature Sensor:contact de température (pour voyant)
Engine Cooling Fan Blade: pale de ventilateur
Engine Cooling Fan Clutch: embrayage de ventilateur
Engine Cooling Fan Spacer Kit: kit d'entretoise pour hélice de ventilateur
Radiator: radiateur
Radiator Cap: bouchon de radiateur
Radiator Cap Adapter: adaptateur pour bouchon de radiateur
Radiator Drain Petcock: robinet de vidange du radiateur
Radiator Lower Hose: durite basse du radiateur
Radiator Upper Hose: durite haute
Thermostat: idem
Thermostat Housing Gasket:joint du logement du thermostat
Thermostat Housing/Water Outlet: logement du thermostat / sortie d'eau (du bloc moteur)
Water Outlet Gasket: joint de la sortie d'eau
Water Pump: pompe à eau
Water Pump Gasket: joint de pompe à eau
D:
Drivetrain: train roulant
Axle Differential Bearing: roulement de pont
Axle Differential Bearing and Seal Kit: kit de roulement de pont et joints
Differential Cover Rear Gasket: joint du carter arrière du pont
Differential Gear Case: corps du différentiel
Differential Pinion Bearing: roulement du couple cônique
Differential Pinion Seal: joint du couple cônique
Drive Shaft Center Support Bearing: roulement du palier d'arbre de transmission
Front Drive Shaft Bushing: bagues avant de l'arbre de transmission
Universal Joint: croisillon
Universal Joint C-clip: circlips de croisillon
Universal Joint Strap Kit: kit de rénovation de croisillon
E:
Electrical: électrique
Alternator: alternateur
Alternator Brush Set: balais d'alternateur (charbons)
Alternator Capacitor: condensateur d'alternateur
Alternator Diode: pont de diodes (redresseur)
Alternator Drive End Bearing: roulement d'alternateur
Battery Cable: idem
Engine Control Module (Computer): module de contôle du moteur
Flasher: clignotant
Generator Brush: balais de dynamo
Horn: avertisseur sonore
Instrument Cluster Voltage Regulator: régulateur de tension des instruments du tableau de bord
Starter Bearing: roulement de démareur
Starter Brush: balais du démareur
Starter Bushing: bagues du démareur
Starter Drive: commande du démareur
Starter Motor: moteur du démareur
Starter Solenoid: solenoide
Starter Solenoid Repair Kit: kit de réparation du solénoide
Turn Signal Flasher: clignotant pour changement de direction
A/C Clutch Coil Connector: connecteur de la bobine de l'embrayage du compresseur d'air conditionné
A/C Relay Connector: connecteur du relais de l'air cond
Headlight Dimmer Connector: connecteur de l'inverseur codes / phares
Heater & A/C Switch Connector: connecteur de l'interrupteur chauffage et air cond
Ignition Control Module Connector: connecteur du module de contôle du contact
Pigtail: ensemble de fils (torron de cables)
Trailer Connector: connecteur de remorque
Voltage Regulator Connector: connecteur du régulateur de tension
Electrical-Lamp & Socket: ampoules et douilles
Back Up Lamp Socket: douille pour ampoules de feux de recul
Back Up Light: feux de recul
Brake Lamp Socket:douille pour ampoule de feux stop
Brake Light: feux stop
Courtesy Light: lumières de courtoisie (éclairage intérieur)
Dome Light: plafonnier
Headlamp Socket:douille pour ampoule de phare
Headlight: phare
High Beam Indicator Light:témoint de plein phare
Instrument Cluster Lamp Socket: douille de lampe du combiné d'instruments
Instrument Panel Light: éclairage du tableau de bord
License Light: éclairage de la plaque d'immatriculation
Marker Lamp Socket:
Parking Lamp Socket: douille pour lampe de feux de position avant
Parking Light: feux de position avant
Side Marker Lamp Socket: douille pour lampe de feux de position latéraux
Side Marker Light: feux de position latéraux
Step Light:
Tail Lamp Socket: douilles pour lampes de feux arrières
Tail Light: feux arrières
Turn Signal Lamp Socket: douille pour lampe d'indicateur de direction
Turn Signal Light: indicateur de direction
A/C Clutch Switch: contact de l'embrayage du compresseur d'air cond
A/C System Switch: interrupteur du système d'air cond
A/C and Heater Control Switch: interrupteur de contrôle du système d'air cond et du chauffage
Back Up Lamp Switch: contact des feux de recul
Brake Light Switch: contact des feux stop
Dimmer Switch: inverseur codes/phares
Door Jamb Switch: interrupteur feuillure de porte
Door Lock Cylinder Switch: interrupteur de verrouillage de porte
Door Lock Relay: relais de verrouillage de porte
EGR Time Delay Switch: contact temporisé de l'EGR
Electric Fuel Pump Inertia Switch: contact à inertie de la pompe à essence électrique
Fuel Injection Pump Switch: contact de la pompe d'injection
HVAC Blower Control Switch: contacteur de la soufflerie
Headlight Switch: interrupteur pleins phares
Horn Relay: relais de klakson
Ignition Starter Switch: contact allumage démareur
Neutral Safety Switch: contact de la sécurité point mort (boite auto)
Oil Pressure Switch: manocontact de pression d'huile
Ported Vacuum Switch: contact à dépression
Starter Relay: relais de démareur
Starter Solenoid Switch: contact du solenoide de démareur
Starter Switch: contact de démareur
Turn Signal Switch: contact d'indicateur de direction
Emission:
Air Charge Temperature Sensor: capteur de température d'air à l'admission
Air Check Valve: soupape de contrôle d'arrivée d'air
Air Pump: pompe à air
Air Pump Check Valve: soupape de contrôle de pompe à air
Air Temperature Sensor: capteur de température d'air
Crankcase Breather Element: reniflar de carter
EGR Valve: soupape EGR
EGR Valve Gasket: joint de soupape EGR
Emission Vacuum Valve: clapet à dépression
HVAC Control Duct Hose: durite de contrôle du HVAC ????
Oxygen Sensor: capteur d'oxygène
PCV Valve: soupape de ventilation
PCV Valve Grommet: logement de la soupape de ventilation
Vapor Canister Filter: filtre du réservoir de vapeurs
E:
Exhaust: échappement
Catalytic Converter: pot catalytique
Clamp: collier
Exhaust Header: collecteur d'échappement
Exhaust Manifold: pipe d'échappement
Exhaust Manifold Gasket: joint pour pipe d'échappement
Exhaust System Hanger: fixation du système d'échappement
Muffler: silencieux d'échappement
Pipe: tuyau d'échappement
Fuel/Air:
Air Cleaner Mounting Gasket: joint du boitier de filtre à air
Air Filter: filtre à air
Carburetor: carburateur
Carburetor Choke Pull Off: levier de starter
Carburetor Choke Thermostat: thermostat du starter
Carburetor Dash Pot: amortisseur de retour
Carburetor Mounting Gasket: joint d'embase
Fuel Filter: filtre à essence
Fuel Pre-Heater Hose: durite de préchauffage
Fuel Pump: pompe à essence
Fuel Pump Gasket:joint de pompe à essence
Fuel Tank: réservoir d'essence
Fuel Tank Cap: bouchon de réservoir d'essence
Fuel Tank Selector Valve: electrovanne de sélection du réservoir d'essence (si plusieurs réservoirs)
Fuel Tank Sending Unit: jauge à essence
Fuel Tank Strap: sangle de maintien du réservoir d'essence
Machine Screw: visseuse
A/C Accumulator: accumulateur
A/C Compressor: compresseur
A/C Compressor Clutch: embrayage du compresseur
A/C Compressor Clutch Bearing: roulement de l'embrayage du compresseur
A/C Condenser: condenseur
A/C Evaporator Core: evaporateur
A/C Expansion Valve: soupape d'expansion
A/C Receiver Drier: assêcheur
Blower Motor: moteur de soufflerie
Blower Motor Wheel: "hélice" de soufflerie
Heater & AC Controls: commandes du chauffage et de l'air cond
Heater Case Drain Hose: durite de vidange du boitier de chauffage
Heater Control Valve: soupape de régularisation du chauffage
Heater Core:
Heater Hose: durite de chauffage
Valve: soupape
Ignition: allumage
Coil Resistor: bobine
Control Module: module de contrôle
Distributor: allumeur (delco)
Distributor Cap: chapeau de distributeur
Distributor Cap and Rotor Kit: kit doigt et chapeau d'allumeur
Distributor Ignition Pickup: capteur d'allumage
Distributor Rotor: doigt d'allumeur
Distributor Vacuum Advance: avance à dépression
Ignition Coil: bobine d'allumage
Ignition Reluctor:
Ignitor:
Spark Plug: bougie
Spark Plug Non-Fouler: bougie non encrassée
Spark Plug Wire Set: jeu de fils de bougies
Tune-Up Kit: kit d'assortiment
Repair Manual: manuel de réparation
Steering: direction
Drag Link: bielle principale
Gear Box: boitier d'engrenages
Idler Arm: relais de direction
Power Steering Control Valve Seal Kit: kit de joint de la soupape de contôle de la direction assistée
Power Steering Filter: filtre de la direction assistée
Power Steering Pressure Hose: durite de pression de la direction assistée
Power Steering Pump: pompe de la direction assistée
Power Steering Pump Drive Shaft Seal Kit: kit de joint pour l'arbre de la pompe d'assistance de la direction
Power Steering Pump Rebuild Kit: kit de réfection de la pompe d'assistance
Power Steering Pump Seal Kit: kit de joints pour la pompe d'assistance
Power Steering Pump Shaft Seal: joint d'arbre de la pompe d'assistance
Power Steering Reservoir Line Hose: durite du réservoir de la direction assistée
Power Steering Return Hose: durite de retour
Rack and Pinion Seal Kit: kit de joint de crémaillère
Steering Damper: ammortisseur de direction
Steering Gear: boitier de direction
Steering Gear Input Shaft Seal: joint de l'arbre d'entrée du boitier de direction
Steering Gear Pitman Shaft Seal: joint de l'arbre de sortie
Steering Gear Rebuild Kit: kit de réfection du boitier de direction
Steering Gear Seal Kit: kit de joints du boitier de direction
Steering Gear Worm Shaft Bearing: roulement du chemin de billes du boitier de direction
Steering Gear Worm Shaft Seal: joint du chemin de billes du boitier de direction
Tie Rod End: biellettes
Tie Rod End Adjusting Sleeve: manchon de réglage des biellettes
Suspension:
Alignement Kit kit d'alignement
Alignment Thrust Plate: plateau d'alignement
Ball Joint: rotule
Coil Spring: ressort boudin
Control Arm: bras
Control Arm Bumper: butée de bras
Control Arm Bushing: bagues de bras
Leaf Spring: ressort à lames
Leaf Spring Bushing: bagues de ressort à lames
Leaf Spring Helper:
Shock Absorber: amortisseur
Stabilizer Bar Bushing: bagues de barre stabilisatrice (anti-rouli)
Stabilizer Bar Link: biellette de barre anti-rouli
Strut Rod Bushing: bague des bras de poussée
Strut Rod Lock Nut: écrou des bras de poussée
Idler Shaft Bearing: roulement de l'arbre relais
Input Shaft Bearing: roulement de l'arbre d'entrée
Oil Pump Housing Seal: joint du corps de la pompe à huile
Output Shaft Bearing: roulement de l'arbre de sortie
Output Shaft Seal: joint de l'arbre de sortie
Shift Shaft Seal: joint du levier de commande
Bon pour ce soir ça ira comme ça. La boite auto, la boite mécanique, les roues et les essuie-glaces on verra demain.
A+
Désolé pour la double liste, j'ai du faire une erreur quelque part en cours d'écriture.
Seule la dernière, la plus complète, est a conserver. Je compte sur les "big boss" pour enlever si c'est possible celle qui ne sert à rien. Merci d'avance.
Salut me revoila et c'est parti pour la suite
Transmission-Automatic: boite automatique
Auto Trans Oil Cooler: radiateur d'huile de boite auto
Bands: bandes frein
Bushings: bagues
Clutch Cam Bearing: palier de came d'embrayage
Clutch Plates: plateaux d'embrayage
Extension Housing Bearing: roulement de chapeau extérieur
Extension Housing Seal: joint de chapeau extérieur
Filter Kit: kit de filtre
Flexplate:
Front Pump Oil Seal: joint avant de pompe à huile
Gaskets: joints
Master Repair Kit: kit de réparation majeur
O-Rings & Seals: circlips et joints
Oil Pan: carter d'huile
Oil Pan Gasket: joint de carter d'huile
Overhaul Package: ensemble de réfection
Ring Gear: couronne
Sealing Rings: joint torique
Selector Shaft Seal: bague du levier de selection
Shift Kit: kit de levier
Shift Shaft Oil Seal: joint du levier de commande
Sprag Assembly:
Torque Converter Oil Seal: joint du convertisseur de couple
Transmission Mount: silent bloc de boite
Washers: rondelles
Transmission-Manual: boite mécanique
Countershaft Bearing: roulement d'arbre intermédiaire
Drive Shaft Bearing: palier d'arbre de transmission
Drive Shaft Seal: joint d'arbre de transmission
Flywheel: volant moteur
Flywheel Bolt: boulon de volan moteur
Flywheel Ring Gear: couronne de volant moteur
Input Shaft Bearing: palier d'arbre d'entrée
Input Shaft Seal: joint d'arbre d'entrée
Main Shaft Bearing: palier d'arbre moteur
Main Shaft Pilot Bearing: roulement d'arbre moteur
Main Shaft Seal: joint d'arbre moteur
Output Shaft Bearing: palier d'arbre de sortie
Output Shaft Seal: joint d'arbre de sortie
Reverse Idler Bearing: palier du levier de marche arrière
Top Gasket: joint supérieur
Wheel: roue
Wheel Lug Nut: écrou de roue
Wheel Lug Nut Lock: écrou anti-vol ????
Wheel Lug Stud: goujon de roue
Washer Pump: pompe de lave glace
Wiper Arm: bras d'essuie glace
Wiper Blade: balais d'essuie glace
Wiper Blade Refill: rechange de balais d'essuie glace
Wiper Linkage Bushing: bague de la tringlerie de commande des essuie glaces
Wiper Motor: moteur d'essuie glace
En espérant que celà vous soit utile.....
